FreeBeeTony
- May 15, 2002
- 3,991
I am in the process of rebuilding the carbs on my '89 88hp evinrude. The Clymer manual does not give specs for the adjustment of the float, it just says to use an OMC gauge. Can someone supply me with these dimensions? There should be 2 dimensions: 1 for the up position and 1 for the down. The rest of the rebuild looks very simple, just take it apart, replace gaskets, needle valve and seat and clean everything.<br /><br />Thanks in advance.
