  #1
Old May 26th, 2002, 08:15 AM
bokarlsten bokarlsten is offline
Default 1990 Evinrude 70 smoke
My Evinrude 70 smokes a lot at idle and low RPMVRO is disconnected.I have mounted a new headgasket and thermostat. At higher RPM it works fine. It works fine also at idle but it´s irritating with all that smoke. Fuel/Oil ratio is 50:1. The engine has been stored for a couple of years, maybe that can harm the carbs, Also when pressing the bulb on the fuelline it never gets firm. (Pls bare with my spelling I´m from a´broad.)Any suggestions??
  #2
Old May 26th, 2002, 08:32 AM
JB's Avatar
JB JB is offline
Default Re: 1990 Evinrude 70 smoke
Howdy, SS.It is normal for 2 strokes to smoke. It seems like a lot more at idle because the smoke sufaces right behind the boat. At higher speeds the smoke surfaces quite a way behind, and is spread out.If your primer bulb does not get firm, you may have one or more carbs with leaky float needles causing one cylinder to run too rich. That would cause extra smoke. An inspection of the spark plugs would help determine the health of your engine. Slight tan deposits and slightly moist is a normal plug. Black and sooty or lots of carbon and wet with fuel is a sign that cylinder is too rich.Let us know what you find.
__________________
RED SKY at night. . .
JB
  #3
Old May 26th, 2002, 12:00 PM
Thanks for your reply!The plugs are new and looks fairly ok. a bit oily moist on them, maybe a bit too much.I believe it could be a good idea to change floatneedles and see if makes a difference. Would that be a major job??
  #4
Old May 26th, 2002, 12:47 PM
JB's Avatar
JB JB is offline
Not hard at all, SS, if you have a manual. If you don't it would be a very good idea to get one or borrow one from a library.Good luck.
__________________
JB
  #5
Old May 26th, 2002, 01:05 PM
Thank´s JB I will borrow one and try that. If it doesn´t work I will come back to you for more advise.brgds SS
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Excessive smoke '85 150 Evinrude sabbett4 Johnson & Evinrude Outboards 3 March 31st, 2007 02:08 PM
1984 Evinrude oil & smoke NCDave Johnson & Evinrude Outboards 7 March 27th, 2004 07:35 AM
Smoke ? 1999 Evinrude 70 Four Stroke neumanns Johnson & Evinrude Outboards 2 July 24th, 2003 06:40 AM
120HP Evinrude Smoke at Start - Help mcneidm Johnson & Evinrude Outboards 5 April 4th, 2002 10:11 AM
evinrude 200- excessive smoke tuxcedo88 Johnson & Evinrude Outboards 2 March 29th, 2002 03:30 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
