Subject: Evinrude Outboard 1993 175 Hp Serial No.175EXETG
We have the above engine and want to buy Standard new Ring sets (part No. 433096)
however 5 of the piston heads have one thick ring and one thin ring (one flat I think and one, the thin one, concave) these pistons are original - is this true or are they both flat?
1 piston head which was changed and has 2 thick rings (should they both be flat, one flat and the other concave?) and I dont know their number part...
I would like to know if it is ok to have this apparently different piston head working with the other five, it looks the same size and weight etc.,
I really dont know where the changed piston came from? Did Evinrude change the ring configuration along the way and if so is it ok to use the two thick rings piston with the other five?
