Re: max rpms for a 91 johnson pro 60 hp
Your max rpm's should be around 5500. If you intend to pull a skier this will greatly decrease the rpms due to the weight of the load.<br /><br />Consider using the current prop you have on and try that first. What are you currently using and what rpms are you turning?<br /><br />Bob
