Just acquired a 94 evinrude 88 spl. Compression 130 - 135. First question... is the compression ok? Ran it on the muffs, sounded ok. Checked the gauges and it appeared that the amp meter was showing battery voltage. I wouldn't get rpm up much above idle on the muffs and I don't know if more rpm would help. Checked my new clymers on rectifier replacement and I got confused. Seems like the Rectifier/Regulator is located behind the wiring buss but the book talks about one under the flywheel. Pictures showed something different from what I see on mine. Can you clarify what I'm sposed to be seeing?
