desprite for help on outboard 70 hp johnson
lewis1
having problem with motor not opening up once in the water. just put on new 13 pitch prop. carbs where rebuilt,new fuel pump, new plugs. still not opening up once at lake. they fuel primer bulb is going soft when opening up throtle. stay hard when trolling. and can anyone tell me what they mix ratio i should be using they guy i boat this from said 50to1. the motor is a 1985 70hp johnson elpto it is oil injected but it was removed.
fireman 757
Re: desprite for help on outboard 70 hp johnson
Check your ignition coils/power packs. Probably breaking down under a load.
b.gagnon
Master Chief Petty Officer
Check the fuel lines in the boat. It sounds like you have a leak.. The bulb should always stay hard.
lewis1
coils and power packs are new.thanks for info though. fuel hose is one of they items i am changing right now. but i was also told that the jets maybe dirty and need cleaned and or replaced.<br />also would anyone know what they exact spark plug should be.
rickdb1boat
QL77JC4 Gap .030<br /><br />Rick
