i have a 1990 johnson sailmaster 9.9. i was motoring for several hours one day then ran out of gas. i poured 2 cycle oil using a 50:1 ratio into a new tank of gas but did not mix the oil well. i started it up and eventually noticed excessive smoke after shifting from forward to reverse numerous times while manuevering in port . i tilted the engine up and noticed oil dripping from the water discharge between the propeller and anti-suction plate below the waterline on the port side. i ran it 2 days later after stirring the gas/oil in the tank thoroughly and noticed the same problem. is the oil leak due to using a 50:1 gas/oil ratio opposed to the recommended 100:1 (yes the manual actually recommends this ratio) or did a gasket fail in the lower unit causing lower gear oil to mix with cooling water or is it something else?
