  #1
Old August 27th, 2002, 09:57 AM
wrj9892 wrj9892 is offline
Default Can't get Forward w/o Losing Reverse - 79 Evinrude 150 V6
Backed away from the dock and went to go forward. No forward gear. Motor just revved up. I had worked on the fuel lines a couple of days earlier and had moved the air silencer from the front of the carburetor without detaching the throttle and gear linkages. Finally adjusted the linkage and got forward gear back......but lost the reverse gear. Finally limped back to the dock and took the boat out. The next day, I worked on the motor and tightened down the cable holding clamp. I think I've got both gears back now...at least out of water. Haven't taken it back out yet. Any suggestions if I still have problems?
  #2
Old August 28th, 2002, 07:37 AM
Default Re: Can't get Forward w/o Losing Reverse - 79 Evinrude 150 V6
  #3
Old September 3rd, 2002, 06:42 AM
Have had the boat out a couple of times since, can't get both forward and reverse - just one or the other. Sunday we started noticing the motor start to race and then slow down. Finally slipped out of gear. Tightened the linkage and ran fine for a while and then started to slip again. Took it out of the water and will check this week. Any ideas?
  #4
Old September 3rd, 2002, 03:25 PM
  #5
Old September 3rd, 2002, 03:53 PM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
I cant tell from your post but are you losing the gears with the cable connected or disconnected? What happens if you leave the cable off and shift it by hand? If you have the gears then I would guess your cable has streached and should be replaced.Good luck!
  #6
Old September 3rd, 2002, 03:57 PM
The problem is with the cable connected. I'll try tonight to shift with the cable off.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
No Forward or Reverse on 95 25hp evinrude banqman1000 Johnson & Evinrude Outboards 1 May 24th, 2006 03:29 PM
1970 Evinrude 100 no reverse; no power going forward cjs12870 Johnson & Evinrude Outboards 2 June 19th, 2005 08:59 PM
1984 Evinrude 115 - No Forward or Reverse mulv80 Johnson & Evinrude Outboards 9 June 1st, 2005 08:08 AM
1987 evinrude 50hp no forward or reverse mkoz Johnson & Evinrude Outboards 5 March 27th, 2005 08:32 AM
93115 Evinrude - Goes forward while in reverse! JWRoberts Johnson & Evinrude Outboards 2 August 5th, 2003 09:46 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
