  #1
Old August 22nd, 2002, 02:20 PM
moonlight moonlight is offline
Default Evinrude 3 hp 1947 ? 1 cylinder dead-intake crankshaft valve?
I have a outboard with one (lower) cylinder dead.It has spark, It has compressionand I think it's not getting gas in that cylinder.I can blow air out theexhause, and through the reed valve out the cylinder, so it's not blocked.The "reed" valve on the output of the carburator looks clean and nice.I have not been able to take apart the crankshaft portion of the motor. I can see a "spiral" looking thing through the reed valve port. I think there must be a way for the cylinder to closeoff and create vacuum to pull the gas in. Does anyone know if this is true? It's not clear to me how to open the crankshaft area, even after pulling the flywheel, there'sstuff on top that looks like it's press fitted on. Am I on the right track?Advice? comments?
  #2
Old August 22nd, 2002, 04:49 PM
JB's Avatar
JB JB is offline
Default Re: Evinrude 3 hp 1947 ? 1 cylinder dead-intake crankshaft valve?
Yes, Moonlight, I think you are on the right track.There is a cover over the bypass from crankcase to the scavenging ports. I think the gasket is leaking or even missing. That would prevent the crancase from drawing a vacuum to bring fuel/air in and from making pressure to pump it into the cylinder.If your reeds are sealing properly and you have good spark, something is preventing the scavenging pump action of the piston and crankcase. The bypass cover is most likely, but you may also have blown a crank seal.Good luck.
__________________
RED SKY at night. . .
JB
  #3
Old August 22nd, 2002, 06:08 PM
almost retired again almost retired again is offline
Hello Moonlight,No one else has answered your post, so I'll try to respond. If you have taken the carb. off and can see the reed valves you souldn't be able to see past them. Crankcase pressure pushes them closed, and crankcase low pressure pulls them open allowing the fuel/air mixture to be pulled into the crankcase, and thru the intake ports to the top of the cyls. I'm not positive, but I think that you can remove the reed valves without seperating the crankcase. What I've just said is true on Johnsons/Evinrudes, but if it's a Mercury you will have to seperate the crankcase halves to get to them. They are installed on the crankshaft.Good Luck
  #4
Old August 22nd, 2002, 08:16 PM
JB's Avatar
JB JB is offline
I resent your smart alec remark, ARA.
__________________
JB
  #5
Old August 23rd, 2002, 07:40 AM
Dear JB,Great! Good to get confirmation. The only thing I'm unsure of is how to open the crankcase up. There's a ring on top, that I"m not sure how to get off.dear almost retired,Thanks for the reply. On the evinrude, the reed valves come off easily, and I removed them. That's how I could see past them.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Dead Cylinder - Evinrude 48 HP SPL - HELP! papakevin Johnson & Evinrude Outboards 8 April 21st, 2005 07:14 PM
aq125 intake valve porkchop27 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 8 September 1st, 2004 03:36 PM
Evinrude top cylinder dead packfan1967 Johnson & Evinrude Outboards 5 July 2nd, 2003 10:14 PM
how to open crankshaft of 3 hp 1947 evinrude moonlight Johnson & Evinrude Outboards 1 August 23rd, 2002 07:30 PM
stuck intake valve...cause of water in block?? mike9190 Non-Repair Outboard Discussions 1 August 7th, 2001 11:03 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
