1975 Evinrude 115,no spark
scrubbie38
I have just purchased a 1975 proline 17' with a 115 Evinrude motor. It will not start. I checked for spark and there is none. I took it to a shop and he said that the ignition plate was bad and that the powerpack was going. He said he grounded the sensor and it started.It started again when i got it home,but the next morning it would not start. again no spark.Any help would be nice,Ron
Bob_VT
Re: 1975 Evinrude 115,no spark
Well... You were told by the shop what was going and what was gone. I would replace the things it needs. By passing or grounding sensors is not the way to go.<br /><br />You could purchase a manual and do the work yourself.<br /><br />Bob
clanton
Remove all sparksplugs, ground the sparkplugs wires, check spark at 1 wire using fully charged battery. If you now have spark adjust timing sensor air gap.
