distributor cap for 71 60hp johnson.
mookieo2
i recently bought a 1971 johnson 60hp and found that the distributor cap is cracked where the plug wires screw into the cap. does anyone know a fix for this or should i try to find a new one. the plug boot covers where the piece cracked off. maybe some silicon or something can be put on it to seal it. a small piece is broken off on two plug wires.
steelespike
Re: distributor cap for 71 60hp johnson.
If the cap works and the wires stay in leave well enough alone. If you must you could try something like silicone but something that cures harder<br /> not sure what would be best possibly E6000<br /> Good luck.
