Re: No fire from 1972 50h.p. Johnson
The rectifier location? Find the terminal board. Close by that board will be a metal object with a round tower like appearance. It's base will be sort of triangular shaped. It will have three wires leading from it to the terminal board, a yellow, a yellow/gray, and a red wire. That's the rectifier. Some rectifiers also have a yellow/blue wire. The method for checking a rectifier is as follows.<br /><br />Remove the rectifier wires from the terminal block. Using a ohm meter, connect the black lead of the ohm meter to the rectifier base (ground), then one by one, connect the red lead of the ohm meter to the yellow, yellow/gray, then the red wire (some rectifiers may also have a yellow/blue wire. If so connect to that also). Now, reverse the ohm meter leads and check those same wires again. You should get a reading in one direction, and none at all in the other direction. <br /><br />Now, connect the black lead of the ohm meter to the red wire. One by one, connect the red lead of the ohm meter to the yellow, yellow/gray, and if present, the yellow/blue wire. Then reverse the leads, checking the wires again. Once more, you should get a reading in one direction and none in the other. <br /><br />Note that the reading obtained from the red rectifier wire will be lower then what is obtained from the other wires. <br /><br />Any deviation from the "Reading", "No Reading" as above indicates a faulty rectifier.
