On my Johnson 175 Oceanpro. Engine shuts off suddenly at different rpms and I may have narrowed it down to low voltage. I replaced the battery a week or so ago and the problem went away until Saturday morning. Was using running lights early and motor shut off again. Wouldn't fire at all. Fished awhile and turned lights off when it was light enough. After a while tried motor. It started right up and ran with no problems. Monitored voltage when I figured out the light thing (motor has cut off when using running lights many times). The voltage is 13.9 running at 3500 rpm. With lights it drops to 12.4. <br />Finally the question:<br />Should I just change the voltage regulator or is there a way to check it. My running lights go dim when I key the radio too.<br />thanks for any suggestions<br />fc
