Hi Folks, <br /><br />I've just rebuilt my power head, the plugs were clean and found that the cylinder head and block were warped. Got the motor back together and now I have this problem. Runs great at idle and from midrange to WOT, but the engine misses in the midrange. Another clue, the top plug is wet while the bottom is dry but black. I switched the ignition, meaning I swapped the plugwires and wires to the primaries ... same result, so it looks like I can discount the ignition. Thinking that it may have something to do with the high bow before she planes off. In that vein I bent the float tang in the carb to try and help lean things out, no change. The thermostat was just replaced and the temperature seems to be fine (by the touch of the hand)<br /><br />Any advice would be greatly appreciated. <br /><br />~John
