I have this engine hoisted up, I want to verify that I can get it to run before trying to put it on the boat.<br /><br />I have connected +12v from the battery to the starter solenoid (Battery post) and neutral shift solenoid, and I also wired a switch +12v to the start terminal on the solenoid, I can use this switch and crank the motor over fine with the starter motor.<br /><br />The problem is ignition. I don't have a spark. I ran +12v to the purple wire on the amplifier assembly (power pack?). The blue wire from the amplifier assembly goes to the blue wire on the coil. The gray wire from the amplifier assembly is not connected to anything, as shown in my Seloc wiring diagram. The black with white tracer goes to the points.<br /><br />On outboardparts.com , I found a troubleshooting page.. It was sort of hard to follow, but I think it says if I connect the black w/ white tracer from amlifier assembly to ground, I should get a spark from the coil? I tried that, and no spark from the coil wire to the engine block. Does this mean for sure that my amplifier assembly is bad? All of the other wiring I have left intact. What other wires do I need to check, or connect to +12v?<br /><br />this outboard newbie needs help! thanks<br /><br />Mark
