Songdog
The tool the manual is refering to is a simple cut out to ensure that the float is parallel. you can make one yourself by taking some stiff cardboard and cut out the width of the float bowl and as deep as the top of the float. make sure the cut in and the bottom are parallel. Or your service manual probably will give you a measurement from the bowl wall to the top of the float. or (after all this)Hooty has a very good suggestion.
