motor missed at speed sometimes, but warm would run great. occasional oil warning, thought possible short. has vro. running fine today and then clunked, stopped turning the screw and overrevved, even at idle postition on restart attempt, so i got towed home. on restart no water out of indicator. i think it might have a bad ground on a coil,causing the intermittent miss, but haven't found it yet. any thoughts on what broke and where to start? sometimes what appears to be oil (Lower gear oil?)leaks out on outer housing below powerhead. did i cook a seal and bust a shaft? obviosly the water pump is not working. does the lower unit pump its oil up the shaft to the powerhead? if i put it in gear with engine off shouldn't i feel compression when i turn the prop? i don't now.
whoops. any thoughts are appreciated as to where to start to get back on the water.
