Will 71' 6hp Evinrude run on 50:1 mix ?
Rod Holder
Ahoy,<br />Looking at a kicker but want to make sure it is 50:1 (same as my main).<br /><br />Thanks ...........
rolmops
Re: Will 71' 6hp Evinrude run on 50:1 mix ?
Yes,it will run just fine on 1:50<br />Because this is a kicker,as you say.You might want to consider to always use a winterizing amount of stabil.Also because this engine will not run very much,it might be a smart idea to go down to 1:40 or even 1:32 so that you will always have that little bit of extra oil that keeps your engine innards well lubricated while not in use<br />Good luck.
