  #1
Old August 4th, 2002, 02:35 PM
Squeakit Squeakit is offline
Default old evinrude vent/drain screws
I want to replace the vent/drain screws on my 1957 Evinrude Fisherman 5.5hp lower unit, but I have purchased 5 different sets of screws locally and they have all been too large in diameter to fit down into the recessed holes in the gearbox. Everyone says these are the standard OMC replacement screws. Are the older screws slightly smaller or do I have a weird lower unit? Can anyone with an old Fisherman shed some light on this?
  #2
Old August 4th, 2002, 06:21 PM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
Default Re: old evinrude vent/drain screws
Squeakit.... That got me curious so I checked my remaining stock. The later drain screws that incorporate a "O" Ring have a thicker head, not wider, just thicker. The eariler ones that use a nylon washer are slightly thinner. Why are you replacing them?
  #3
Old August 4th, 2002, 09:45 PM
Joe - thanks for replying. I'm replacing them because the screw slots are kinda buggered up from someone using the wrong size screwdriver I guess. The problem is that the newer screw heads are just a little too large in diameter to fit down into the recess. It's an extremely small difference but prevents me from using them. The original washers were a fiber material and the new hard white neoprene washers dont seem to fit right either. I put the old screws back in and used O- rings and teflon tape on the threads. Haven't tested them out yet. Would still like to replace the screws.
  #4
Old August 5th, 2002, 06:16 AM
oldboat1 oldboat1 is offline
Ensign
I don't think the new drain screws would protrude out far enough to make any difference in operation. You might try using the plastic washers after you heat them to make them more pliable -- might allow the drain screw to fit in a little deeper. Drop them into very hot water for a few minutes before use.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
O-rings on lower end fill and vent screws? crunch Mercury & Mariner Outboards 11 August 29th, 2006 09:25 PM
1977 Pre-Alpha Vent Screws JFLS40 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 0 July 30th, 2004 11:49 AM
lower unit vent / fill screws? tsutter Mercury & Mariner Outboards 4 September 2nd, 2003 07:45 PM
oil drain screws frozen mstein63 Johnson & Evinrude Outboards 3 June 25th, 2002 07:33 PM
How tight vent and fill screws 40 Merc? ezbtr Mercury & Mariner Outboards 5 May 29th, 2002 06:45 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
