I am having problems with my '72 Evinrude 9.5 hp. It idles fine, and runs excellent at slow speeds, but when i put the throttle wide open, it bogs down and doesn't go as fast as it used to. Sometimes the choke lever will come out on its own, and this causes the motor to slow down dramatically, but even when the choke doesn't come out it still goes slow at WOT. Yesterday when i unhooked the fuel line to run it out of gas, i put it wide open and took a few runs around the pond. Right as the last bit of gas was running out, it took off, and went faster than I've seen it go in a long time. I get so frustrated, and don't know what the problem is. Any suggestions? Thanks<br /><br />Brent
