  #1
Old July 28th, 2002, 08:50 PM
charlie1939 charlie1939 is offline
Default Evinrude 2; Year? Reinstalling recoil starter spring
"Evinrude 2", single cylinder OB, Model #2502D, S/N E0003182. 1. What year is this? No help at www.evinrude.com for pre-1990 motors!2. What is the trick to reinstall the recoil starter assembly?By mistake, I removed the machine screw holding the recoil starter to the cover. I cannot figure how to rewind the coiled spring, get it aligned with the cast outer web inside the cover and then get the rope pulley located and screwed back together.
  #2
Old July 29th, 2002, 12:08 AM
Allen Henry Allen Henry is offline
Default Re: Evinrude 2; Year? Reinstalling recoil starter spring
Charlie,If your numbers are right and it is a 2 hp motor, it looks to be a 1975 model. try this site to double check: http://www.kencook.com/kccwww/marinepubs/oml06.html Trp251
  #3
Old July 29th, 2002, 08:14 AM
Thanks Trooper, any thoughts on the recoil spring?
  #4
Old July 29th, 2002, 08:34 AM
gsnyder gsnyder is offline
Charlie--Recoil springs can be tough. I disassembled a recoil spring on my 1967 Evinrude 3 hp, and, given my amateur mechanical ability, I took 8 months to figure out how to finally install a new one. I can't tell you how many times that #@$%# spring popped out of my hands and unstrung itself on my garage floor. After I finally figured out that you can attach the spring loops to the pulley and starter head spindles, then squeeze the whole thing back together, then hope that it was the right direction, then coordinate that with the rope direction, then wind up the spring to the proper tension, I got good enough to try a few different options. I did lots of winding and used lots of wd-40. Ultimately, it worked. Anyway, recently I got a couple of manuals which explain the process in far simpler terms and make it sound doable. (Johnson service manual and Clymer) You might also just invest in a professional mechanic unless you have lots of time. Otherwise, if you have lots of time, trial and error can teach you a lot. Good Luck.
  #5
Old July 29th, 2002, 11:05 AM
Thanks 7 1/2,I did figure it out after taking the whole starter assembly apart. Your ideas were right on the money. It has to be wound up and all the parts replaced exactly correctly, I missed aligning a key properly the first time(s). But live and learn, sometimes it is a tough school to get the knowledge! Then, of course, you forget it by the next time you need it. However, I find the challenge of the problem to be enjoyable, so the time doesn't matter so much to me, don't ask my wife though....
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
How do I recoil a starter spring? SliderM72 Johnson & Evinrude Outboards 5 May 31st, 2005 08:39 AM
recoil starter spring Max_Door Johnson & Evinrude Outboards 3 March 5th, 2005 07:22 AM
Replacing recoil starter spring Meaux Johnson & Evinrude Outboards 10 September 6th, 2004 10:26 AM
Reinstalling starter cord for '69 Evinrude 6hp Schritzy Johnson & Evinrude Outboards 4 August 13th, 2003 05:43 PM
recoil spring replacement on 9.5hp Evinrude frankbn Johnson & Evinrude Outboards 4 April 30th, 2003 12:13 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
