Re: 1996 Johnson 225 stalls low idle
You definately want the QL78YC's and .030" is the correct gap. OMC issued a service bulletin (95/96 time-frame) which listed all the spark plug recommendations. It also refers dealers to the current edition of the "Dealer P&A Catalog" (for future reference).<br /><br />Gaps were also changed to .030" - this is to reduce the likelyhood of false alarm signals causing the engine to go into S.L.O.W. (self-protect mode). I was told the engineers discovered spark plug gaps in excess of .045" could cause this - therefore if you start off @ .040"...<br /><br />You might just simply verify your engine's idle speed is correct. The spec is 650 +/- 50 rpm, in the water, in gear, NOT tied to a dock. Personally, I favor the +50 when I set them up. DO NOT rely on the in-dash tach, use an accurate "shop-type" inductive pick up tachometer when setting idle speed.<br /><br />When the engine stalls out, what do the spark plugs look like?? Is/are any one (or more) wetter than the others??<br /><br />-John
