  #1
Old July 27th, 2002, 06:01 AM
campjung campjung is offline
Default Shifting problems-85HP Evinrude
I haven't been able to adjust my linkage so reverse works. When I adjust the cable linkage so reverse works then forward doesn't! The gears grind and the throttle increases so it does't engage. When I re-adjust so forward works, I get the same symptoms in reverse. I wonder if it is more than a linkage adjustment? It is a 1977, 4- cylinder 85 HP Evinrude engine with mechanical shifting.John.
  #2
Old July 27th, 2002, 06:48 AM
Joe Reeves's Avatar
Joe Reeves Joe Reeves is offline
Default Re: Shifting problems-85HP Evinrude
John..... Disconnect the shift linkage at the engine, then shift the engine by hand. This will tell you if the problem exists with the engine (lower unit) or with the remote control assy.
  #3
Old July 27th, 2002, 08:34 AM
Dear Joe,Thank you for your prompt reply. I have done this before and it seemed to work OK by hand. I will try again. I replaced the cable last year as the adjusting knurrled knob was broken. The slim part of the knob fits in the space devoted to it (below the accel adjust knob-covered by an "s" bracket with one screw) but it is "sloppy". Could this be the problem? Is there any way I could make it a tighter fit and still allow for turning and adjustment?Feel free to e-mail me directly at campjung@cs.comThanks so much!!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
88 Evinrude 175 shifting problems schlosss Johnson & Evinrude Outboards 1 May 16th, 2005 07:49 PM
'81 Evinrude 35HP shifting problems sumrskyjam Johnson & Evinrude Outboards 3 June 20th, 2004 06:32 AM
Shifting on a 76 85HP Evinrude spiderjohn Johnson & Evinrude Outboards 6 April 8th, 2004 03:27 PM
1974 Evinrude 85HP V4 shifting noise zj-jeepster Johnson & Evinrude Outboards 6 July 19th, 2003 04:45 PM
1974 Evinrude 85HP V4 shifting noise zj-jeepster Johnson & Evinrude Outboards 3 July 10th, 2003 10:39 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
