  #1
Old July 19th, 2002, 05:54 AM
Luna Sea Luna Sea is offline
Default 85 120hp Evinrude primer bulb problem
Engine has not been able to operate over 33-3500 rpms since I bought it. Earlier I was lead to believe “high speed stator coils were breaking down at high speeds” So I decided not to mess with it this season. But, the other night I had someone squeezing the primer bulb as I throttled up and I was able to hit 4800 rpms and stay there as long as he kept squeezing the bulb. Replaced external fuel lines and bulb when I bought it, internal ones last night and then bypassed internal fuel filter (temporarilly-should this have an air pocket in it???) Have the Seloc manual on my desk, reading about vaccum test, not very helpful. The line coming out of the top of the pump goes down under it and forward. Not very acessible where it goes to. Is that a fitting it goes to? It seems loose. Is this an air/vaccum line or something? I have 2 fuel tanks and switching doesn’t help so I want to troubleshoot a bit more. Any help/suggustions would be appreciated.
  #2
Old July 19th, 2002, 06:46 AM
mellowyellow mellowyellow is offline
Default Re: 85 120hp Evinrude primer bulb problem
this is a classice fuel pump problem. I wouldstart by re-building pumps and go from there.a cheap/easy rebuild with the manual in hand.good luck!
  #3
Old July 19th, 2002, 07:38 AM
Thanks mellowyellow. Pumps? Just one in there I hope.
  #4
Old July 19th, 2002, 09:27 AM
Ted S. Ted S. is offline
Sounds like fuel alright, but check the fuel supply line too that you installed. If a fitting is loose you will draw air into the system causing fuel starvation. My 125 johnson had a similar problem and the fuel pump fixed it right up. Make sure the air pulse hose is ok and not blocked in any way as well. Cheers!
  #5
Old July 19th, 2002, 01:16 PM
Thanks Ted S. Hmm "Air Pulse Hose" That must be whats coming out of the top of the pump. Still need to know what thats connecter to down under where I can't reach. And come to think of it, the engine did used to make more of a sucking/vaccum noise when the high speeds were attained. This hose is a bit kinked cause it makes a 180 degree bend on the top of the pump.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
primer bulb problem? Steve08753 Yamaha & Suzuki Outboards 1 May 23rd, 2006 06:18 PM
Do I need a Primer Bulb? smokeyjoe 2 Mercury & Mariner Outboards 7 June 2nd, 2004 02:32 PM
Collapsed primer bulb on 4 stroke 9.9 Evinrude. MikeMo Johnson & Evinrude Outboards 7 May 31st, 2004 04:50 PM
Primer Bulb dartman Johnson & Evinrude Outboards 13 November 12th, 2003 07:14 PM
Problem with primer bulb / Suzuki dt115 passfred Yamaha & Suzuki Outboards 4 June 16th, 2003 10:17 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
