July 17th, 2002, 06:47 AM
1981 2 cyl Evinrude 2 stroke
How does my Evinrudes fuel system works ?
Please help
Frans
July 17th, 2002, 07:05 AM
Re: 1981 2 cyl Evinrude 2 stroke
I'm still new, but I'll help if I can. I may have the manual for that motor. What horsepower do you have?
Is there something happening that makes you ask this question?
Jason
July 17th, 2002, 07:10 AM
Howdy, Frans.
If it is a 2hp, 3hp or 4hp your engine uses a gravity feed from the tank to the carburetor.
If it is larger, it probably uses a fuel pump operated by pressure pulses in the crankcase. If it is older, it may use a pressurized tank.
Do you have a problem? Tell us your model number and your problem and perhaps we can help.
__________________
RED SKY at night. . .
JB
July 18th, 2002, 07:18 AM
Jason, thanks, it is a 60 hp , it started to struggle to plane the boat. No changes were made,I changed the fuel and got no result
Frans
July 18th, 2002, 07:27 AM
JB, Thanks ,it is a 60 hp and it started to struggle to plane the boat, I changed the fuel with no result, I suspect fuel starvation
Frans
July 18th, 2002, 08:07 AM
What boat (length, approx weight)?
Is it running on all cylinders?
What happens if you squirt fuel into the carbs when trying to plane?
__________________
JB
Thread Tools
Search this Thread
Display Modes
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
