My '86 Evinrude 140 runs great for the first 10-15 minutes we are on the lake. After this, it stalls upon acceleration. It seems to idle ok, and runs great if you can get it up to speed, but getting it there is difficult.
It is definitely a fuel problem as I've discovered that if I hold in the choke as I accelerate, I can prevent the stall (although it still isn't a smooth acceleration).
I've cleaned the carbs (replaced gaskets, needle valves/seats) ensured the intermediate air bleeds (jets?) are per the manual and replaced the fuel filter. When filling the gas tank, some excess gas came out of the vent, so I assume it is not blocked.
I tried pumping the gas line bulb while accelerating, but this seems to have no effect. The bulb does go a little softer than the firmness achieved when you initially pump it, but it is not totally deflated.
Any thoughts on what I can try next?
As always, many thanks to those who take the time to read our endless problems and provide suggestions.
Cheers.
