Re: Help Evinrude 35Hp Still one cylinder
In a 2-stroke outboard, a compression test only tells you what is going on above the top ring when the ports are closed. A bad ring (or rings), scoring/scuffing, or a bad head gasket will not let the engine develop full compression - the compression test will show low if any of these are at fault. As you know the engine needs compression (in the combustion chamber), correct fuel/air ratio, correctly timed spark and the ability to exhaust in order to run.<br /><br />What a compression test doesn't tell you is what is going on in the crankcase, and below the lower ring. If the piston skirts are worn, or the lower ring is stuck in the piston groove, when the piston comes down in the cylinder bore it can't compress the fuel/air mix in the crankcase because the pressure "leaks down" by the lower ring (or piston skirt) and leaks out the exhaust port.<br /><br />Although there is no "text-book" test to check crankcase pressure, a leak down test can clue you into problems a compression test won't reveal.<br /><br />For example, another tech I know was having a problem wilth a 200 horse recently. Compression numbers weren't real high, but something we would all consider good. After repairing several existing problems, the engine still wouldn't run well. For what-ever reason he finally decided to do a leak-down test and found one cylinder leaking down 50% and another 90%. 35 to 40 percent is the max acceptable leak-down. In his case it was a ring in one cylinder and piston skirt in the other.<br /><br />If you have a crankcase seal or gasket leak, you can find it by running the engine and spraying all the crankcase seams, intake manifold etcetera with some engine tuner or fogging oil. As the gapped is momentarily "filled", you'll hear the engine running characteristic change.<br /><br />Keep "talking" with us, we'll bounce some more ideas your way...<br /><br />-John
