Re: dies at full thottle
Hi <br /><br />If you say it helps choking it, ist a fuel blocking somehow, either fuelpump or clocked carbs. Pull hose from fuel pump to carb, and try to cranck the engine holding something under. ( carefull, engine must not start, look up for fire !!! If it pumps, i guess you have to clean and rebuild carbs.
