  #1
Old July 8th, 2002, 03:32 PM
jgrover92064 jgrover92064 is offline
Default 1983, V4 90 hp Evinrude Over heating
I've got a 1983 90 hp Evinrude that up until last Sat ran great. While driving it at approx 25 MPH it lost all power and died, after it died a big puff of white smoke came out from the exhaust and steam came out from the aux tube (pee hole). The engine was so hot it burned the skin off my leg after just touching it. After it cooled down it would run for a little while then die. Sunday it started with the flush adapter connected and water came out through the pee hole but not through the 2 tubes that run from the (I think it's called the) transfer ports (or something like that) to the heads. I took off the lower unit and the water pump/impeller looks good, no cracks or dry rotting. I tried to run water straight through the bottom of the copper pick-up tube to the engine and still no water through the ports, aux (pee hole) yes, engine no. What does this sounds like to you? I'm thinking a clogg somewhere, but where could it be?
  #2
Old July 8th, 2002, 03:37 PM
DJ DJ is offline
Default Re: 1983, V4 90 hp Evinrude Over heating
Skeeter,I have that exact engine.I would pull the thermostat housing and the heads.Thermostats. The housing is between the heads on the bottom rear of the engine. The two large hoses going from the heads go to that housing.Heads. You have prbably cooked both head gaskets. Check for cylinder wall damage. Also, you may have melted the cooling water diverters.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
evinrude v4 110 over heating skidaddy65 Johnson & Evinrude Outboards 6 September 9th, 2004 07:57 PM
1988 15hp Evinrude over heating hdroad Johnson & Evinrude Outboards 10 September 8th, 2004 10:19 AM
60 evinrude over heating alarm alexcalvin Johnson & Evinrude Outboards 2 August 3rd, 2003 07:27 PM
1983, V4 90 HP evinrude over heating jgrover92064 Johnson & Evinrude Outboards 1 July 8th, 2002 05:58 PM
1982 evinrude 88hp engine heating up need help please BadBoy Johnson & Evinrude Outboards 5 June 2nd, 2001 06:39 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
