got an 83' Evinrude 7.5 to go on the back of my 12' john boat. It ran terrible at first, buckin and bouncen around. just sad. I replaced the spark plugs and tried to ajust the fuel mix. no luck there. Took a trip down the Chasahowitzka river to go fishing at the mouth at the gulf. Within sight of the fishing hole she quit. with me i had two small creasnt wrench's and a phillips screwdriver.( now tell me that's just not begging for it.)took out the plugs and messed with everything i saw, nothing. at the time i did not know what the black box on the side of the motor was but i was blisterd, worn out and majorly pissed off. so i smacked it with the creasent wrench... then i pulled it one last time before showen some leg and sticken out my thumb,it started. It got me back to the dock (barely). I called up the local tiller doctor and he told me what i smacked and how much it cost (##@%!*&#) Won't be smacken that again. He said that i should check all of my connections and wires. i took of the power pack and the coils and cleaned up the grounds at both, now it runs a lot better but not perfect. it still has a small bounce but nowhere near like it was. it will run at its lowest part in the slow setting for a while but when i put it in forword most times it will shut off and it goes up and down in rpm's. It will surge when going fast to but i haven't run it since i cleaned up the grounds so we will see. sorry to be so longwinded but i figure if i explain it well i will get more info. on what might be causeing my problems. thank's for not going to sleep on me and will be glad for any advice.
