Re: 35hp Johnson with carb problems. HELP!!!!
Hello medic I,ll try to help. Your float should be turned upside down with the float bowl removed the float should be parallel with the carb. body. When you cleaned it did you use a spray can carb cleaner, or soak it? I personally I like the spray can. If you use a spray can notice one big tube with a smaller one running up through the middle of the bigger one; the smaller one is the one thatsupplies the low speed outlets behind the throttle plate, and as the throttle is advanced it will uncover some more small holes, these are the intermediate supply holes. If you squirt carb cleaner thru the small tube you should see it comming out both the low speed and the intermediate holes. This would be my first guess as to why it dies when you throttle up. these intermediate holes have the same function as an accelerator pump on four stroke engines. I hope this helps.
