Re: Plastic Fuel Tank
Hi dstuard.<br />All inboard (permanent) tanks must be vented. They must also be equipped with an anti-siphon valve on the fuel pickup for the engine. This is to prevent the fuel from siphoning out into the boat. The wire I believe is an anti-static line. This is to prevent any static charge from building up while fueling. I believe all you need to do is connect it to the filler cap. Also make the fuel gage pickup accessable if you are going to install one. These things eventually go bad.
