Hi Pania<br />>how do you know its flooded?<br />>did you check for spark when it won't start?<br />>when it finally starts, does it smoke heavy?<br /><br />(this could be a good excuse to remove VRO and go with pre-mix)<br />we need more info
Pania,<br /><br />Going on what you gave us, I had a 1989 90 that did the same thing. Had to use the warm up lever to "clear it out" every time I started it-when warm.<br /><br />Turned out to be a bad float.
