i bought this motor to find the lower block is cracked and patched with jb weld ..compression is 130 and 145 ..motor runs but sucks air, boggs down and wont take the throttle im sure its starving for fuel with the leaks in several places. was wondering if the motor is worh fixing I have found the part. and do you have to pull the power head ? evrything else on motor seems fine just did not want to sink more money in it unless it will solve my problems Ihave cleaned the carbs and tried to patch the crack just behind the starter bolt . with no luck any suggestions ? thanks skynard
