  #1
Old May 10th, 2002, 08:49 PM
Dennyps Dennyps is offline
Default need 68 Evinrude 2 stroke tune up tips
[68 Evinrude model 3 cylinder model 55873R]: {not starting} Hey All, well I finally got my manual and some time to actually spend on my motor. I checked the compression in all three cylinders and yeeha, they all came in at about 125 psi [give or take 2 lbs whew. Well now I know she has great compression. So the next logical step was to pull the flywheel and check the points [already pulled carbs and cleaned completely, mixed new fuel and checked fuel pump all okay] Upon pulling the rotor and looking into the points area specifically the rotor shaft I found a most unusual thing, there was this for lack of a better word a tension "crap arm type" spring laying down below the points plate {not tight} but wrapped around the shaft, just sort of free floating with only the tension of the "crap like" prongs around the shaft. Could this have been shorting out something like 2 of the 3 cylinders? to describe this spring even further it's about the thickness of a large paper clip with crab arms type bend and a small 3 coil spring that creates a small amount of tension for the crab arms {the inner arms are worn where they were obviously rubbing upon the shaft}. Does this belong somewhere else in the electrical system? I looked in the manual {exploded Picture} and it did not show this spring anywhere, however in one section it described a spring called the "reverse cut-off spring". I looked over the points and one set looked pretty burned. I pulled the set and used electronic contact cleaner on it and hooked it up to my ohm meter [@200] and when closed I get 001 and when open I get the natural disconnect or 1. {for ref the rotor looked a little dirty but all in all okay, I cleaned it} One question I have is when I was testing the spark earlier I had 1 cylinder with spark [top one #3]and the other two [middle #1 & bottom #2]had no spark at all, I mean zip. I chocked this up to probably points [since I don't really know much about 2 point systems]. So am I on the right track here or could this mysterious spring I found be the culpret in this trobleshooting problem? I would appreciate any other little wisdoms or experience to assist in this mystery. Thanks in advance Denny
  #2
Old May 10th, 2002, 10:00 PM
alcan alcan is offline
Default Re: need 68 Evinrude 2 stroke tune up tips
Hi dennyThe spring you describe is very important. It defenetly needs to be in there in good shape. The firing order for you motor is 123 Top cyl is #1 bottom #3. I sent you some trouble shooting imfo. Check dist. cap and rotor very closely for cracks. Clean them well, Try to use these parts if possable. These parts are spendy and are not considered disposable (as automotive are).
  #3
Old May 11th, 2002, 09:18 AM
Hey Alcan, thanks for the tips: two questions 1. the plug wires on this motor are labled #3 [small metal clip] which is currently hooked up to #1 [top] cylinder and #1 wire is hooked up to #2 or [middle] clyinder and last would be #2 which is hooked up to the [bottom] cylinder. {if} these wires are rightly hooked up & labled correctly to the stator then obviously according to your instruction and the manual they are not in the correct firing order. {which would solve the problem of why all of the cylinders are not firing} I cannot find a reference in the manual about which position on the stator/dist cap the wires should be, so how can I test the plug wires position on the actual stator? making sure of course that the true firing order would be as you say 1.2.3. Thanks for your help, Denny
  #4
Old May 11th, 2002, 10:23 AM
Hi DennyRoll the motor until you get TDC on the top cyl. The rotor indexes on the crank shaft, via slot in cam. The rotor will point to #1. The spark plug wire screw into the rotor cap. The type D greese is diaeletric greese. Some one may have mix-up the plug wires. Check your email, I sent you some more stuff.
  #5
Old May 12th, 2002, 03:51 AM
seahorse5 seahorse5 is offline
When you had the flywheel off, did you see that the distributor cap has the number of each cylinder molded into the correct socket for each plug wire?
  #6
Old May 12th, 2002, 09:41 AM
Hey Seahorse, on mine the stator was mounted to the exterior of the distributor {I mean stuck} so I went up to the local boat store who happened to have one on stock. {$240} Anyway's that one had numbers above the towers. So I made an imprint of the bottom and numbered them, so when I got home I just redid the wires on mine using the imprint and I put her all back together and yeha, it ran. I am going to run through the tune up/syncro procedure again today and get her fine tuned as well as check the tranny in the leg. Thanks so much for the post, Denny
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
03 Merc 115 2-Stroke Performance tips stickflipper Mercury & Mariner Outboards 0 February 19th, 2006 05:42 PM
76 evinrude 55 tune up??? breton26 Johnson & Evinrude Outboards 3 April 18th, 2005 05:02 PM
tune up 65 evinrude 18 hp sitko1 Johnson & Evinrude Outboards 1 July 17th, 2003 07:37 PM
tune up for a 35 HP evinrude gysurshot Johnson & Evinrude Outboards 2 June 17th, 2003 09:44 PM
Evinrude tune up bojan Johnson & Evinrude Outboards 2 January 18th, 2003 03:15 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
