  #1
Old May 8th, 2002, 08:58 AM
jguy jguy is offline
Default 1991 Evinrude 70hp Problems (idling)
Well, I finally saved enough money to do it. I purchased my very first fiberglass bass boat, a Stratos. I was so excited about it, I mean it looks sharp! Anyway, I put it into the water yesterday and then I began to feel sick in my stomach......Well, first of all, it cranked up o.k., but I had to knock it out of gear and give it some throttle, and choke it while turning the starter over. It cranked. I ran up river really good. I was feeling good about the boat. Ever since I cranked it, it will not idle whilst out of gear. It'll just go dead. Also, the cranking mechanism is hanging (you can hear it buzzing once the engine is cranked). I have to turn the keys back to disengage the cranking mechanism. Any ideas on how to make this quit sticking? I sprayed it with WD40 and let it sit overnight. My main concern is getting the thing to idle properly. Help!!!!!
  #2
Old May 8th, 2002, 09:23 AM
JB's Avatar
JB JB is offline
Default Re: 1991 Evinrude 70hp Problems (idling)
Hi, Joe.You need to get yourself a manual.Do the linkage and synchronization (link 'n' synch) procedure. That will get the 3 carbs singing the same tune and get your ignition timing to match.Your starter motor isn't supposed to disengage until you turn the switch off of "start". From your description it sounds like it is behaving normally. If I misundrstand, try again.Good luck.
__________________
RED SKY at night. . .
JB
  #3
Old May 8th, 2002, 09:29 AM
Thanks for the prompt response. I will get the manual and do as you say. By the way, how difficult is this procedure? I'm a 25 year old "youngster", "mechanically mental retarded", and have never worked on an engine. I fix PCs/Computers for a living. Also, I'm broke!! LOL The reason that I was worried about the starting procedure is because I could hear a "buzzing/whining" back at the motor until I put the key back into a 90' position. If I'm not careful, I'll actually kill the engine! Confused.....
  #4
Old May 8th, 2002, 09:49 AM
DJ DJ is offline
Joe,Keep hitting that starter drive with WD-40. Also, while your doing that turn the drive by hand. If you turn it counterclockwise (I believe) it will walk up the shaft and visa versa. DO THIS WITH THE BATTERY DISCONNECTED!! It took me a good 1/2 hour of doing this and spraying with WD to get mine to free up.Do as JB said. For close to the same price as a "generic" manual you can get get the original from a Johnson/Evinrude dealer. The sync./link. isn't that hard, just read the manual and familiarize yourself with all the parts.Make sure you are running "clean" fuel with a good TCW-3 rated oil. You may want to run some Ficht Ram oil-it will help clean the carbon out of the engine.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
lower unit problems-1991 70hp yamaha outboard adam1psu Yamaha & Suzuki Outboards 5 October 10th, 2006 11:57 AM
25 Evinrude idling problems Dale Feicke Johnson & Evinrude Outboards 2 May 30th, 2005 11:35 AM
1996 Evinrude 88 Special Idling Problems bartborchardt Johnson & Evinrude Outboards 3 May 25th, 2004 07:22 AM
evinrude idling problems TRANQUILLO Johnson & Evinrude Outboards 15 July 9th, 2003 05:12 PM
evinrude idling problems TRANQUILLO Johnson & Evinrude Outboards 0 July 7th, 2003 04:09 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
