Re: 150 EVINRUDE LOWER UNIT REMOVAL
If its like my '92 200, you need to remove the cowling ( 3/4 screws ) for easy access then remove the pinion bolt (under the carbs) which secures the lower unit shifting rod to the shift lever gadget thingy... I hope this helps.
