Howdy, Gr1ffith. Most of it is the same for all: Disconnect oil lines from tank and pump. Plug oil inlet at pump. Disconnect wires from tank sensor(s). Use 50:1 premix fuel.<br /><br />Different year motors had different sensors at the pump and different wires going to the alarm system. Your Clymer Manual can give you the wiring for your '84. Then you can decide which alarms to keep and which to disconnect.<br /><br />Good luck.<br />JB
