  #1
Old April 28th, 2002, 06:34 PM
puddle pirate puddle pirate is offline
Default evinrude 140 blown again
i have a 1984 evinrude 140 mod#e140tlcrd that has lost a wrist pin snap ring for the 4th time now in the last 6yrs. i will most likely need a new block again. is there any hope for this yr&mod. eng. this is getting expensive?
  #2
Old April 28th, 2002, 06:53 PM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
Default Re: evinrude 140 blown again
The crossflow motor you have is one of the most reliable ones out there. It is very unusual to pop a clip, let alone 4. Tell us exactly what the motor is doing like RPM's, fuel grade, oil, spark plugs and brand of water pump.Good luck!
  #3
Old April 29th, 2002, 08:39 PM
water pump OMC, spark plugs champion L77 jc4,oil TCW3,fuel grade reformulated 89 octane,RPM's 5000 @ WOT, wrist pin snap rings are not true arch snap rings, motor has about less than 100 hours since last build, there is no other cylinder damage other than wrist pin. Was operating at 3800 RPM when it dropped the snap ring under perfect weather conditions. Engine was running cool with ample water supply. The boat is 17.5 ft bass boat, two people in the boat, not over loaded. Any more questions, please reply. I will try to answer them. Thanks!
  #4
Old April 29th, 2002, 09:06 PM
petryshyn petryshyn is offline
Is it always the same piston? Was the sharp edge of the ring installed facing outward? Were they reused from previous overhauls and possibly over-stressed?
__________________
Alias "schematic"
  #5
Old April 29th, 2002, 10:19 PM
hollywood454 hollywood454 is offline
what brand of piston are they using to rebuild you're 140. This sounds like something i've seem before!
  #6
Old April 30th, 2002, 01:46 PM
I agree. If a different brand clip is being used than the piston that is a problem.And 5000 RPM at WOT is really stressing the piston at the wrist pin area anyway even at 3800 RPM.Good luck!
  #7
Old April 30th, 2002, 04:42 PM
omc has 2 different wrist pin snap rings #1 is a 3/4 wire retaining clip.#2 is a truarc snap ring.I was given the wire clip with the rebuild kit from omc. the first 2 rebuilds were professional. I built the last one. I thought I would give some of that C.G. training that you paid for to good use!LOL As for the new pistons I dont rember what brand.
  #8
Old April 30th, 2002, 04:47 PM
isnt WOT for this engine 4500/5500 as per seloc repair manual??
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Is it blown? Arkie55 Johnson & Evinrude Outboards 4 July 15th, 2005 07:30 PM
Blown 20A Fuse '97 25HP Evinrude chrisd3 Johnson & Evinrude Outboards 7 April 26th, 2005 09:28 AM
Ram cap blown apart bobsboat Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 4 July 14th, 2004 09:27 AM
Evinrude 200HP Blown engine barndoor Johnson & Evinrude Outboards 4 February 23rd, 2004 02:55 AM
1981 115 Evinrude blown cylinder pbailey Johnson & Evinrude Outboards 21 September 26th, 2003 02:26 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
