Shift Rod Screw
Jack
I am trying to remove the lower unit off my 1986 175 Hp Johnson. The manual says to remove the retaining screw. Having a hard time getting a screwdriver on the the screw. Is the head a 3/8 inch? Any tricks on getting this screw loose.
Dhadley
Re: Shift Rod Screw
Yep, it'a 3/8" head. se a 1/4" drive swivel on a long extension. Make sure to recheck the shift rod height when reinstalling. <br /><br />Good luck!
Jack
Re: Shift Rod Screw
Thank you very much, will get a 1/4" drive swivel today.
Jack
Re: Shift Rod Screw
Thanks to Dhadley!!! The 1/4" drive swivel did the trick and the lower unit came off. I didn't back the screw all the way out, hoping to make reassembly easier. Thanks again.
