Re: Johnson Head Gasket
Final torque is 18 ft lbs. Start in the center and work your way out. Do it in 4 steps. Snug, 14 lbs, 18 lbs and 18 to recheck. Retorque after 1/2 hour, 5 hours and 10 hours run time. You did surface the head and block, right?<br /><br />Good luck!
