Re: Johnson fly wheel puller
Willie,<br /><br />I just pulled my flywheel today on a Johnson 225. As long as you have the triangular pattern of holes around flywheel nut, you can use a "bolt puller" from Harbor Freight Tools. The entire kit is $4.99. If you don't have a store near you, go to
www.harborfreight.com and search for "puller" it's $7.99 online. Worked PERFECTLY for me.
