Re: 1989 Johnson 150 hp
I do not own one, but my bro do. It has run flawlessly since he bought it new (1988), with two exceptions...It eats coil packs for breakfast, and the L/U seals should be check 2 times a season. This can be done with a pressure tester to 10psi. It's not a big problem,as you would want to replace the impeller at the normal time.<br />Good engine tho, concidering all ob's have thier little "quirks".
