  #1
Old March 25th, 2002, 07:56 AM
tuxcedo88 tuxcedo88 is offline
Default evinrude 200- excessive smoke
have a rebuilt 1993 200 evinrude. starts ok but with a lot of smoke, leaned out carbs 1/3 turn,less smoke(don't want to lean too much).if engine is warmed up and I shut off and leave for about an hour engine will restart but boggs when given gas. the bulb is new but never gets hard. takes three or four times(starting)to get to where it will accept gas. Oil consumption seems high? Could I have an air or vacumn leak in fuel system? Would this cause excessive smoke?, and hard restarting problem?Any help would be most appreciated [*]null
  #2
Old March 25th, 2002, 12:17 PM
ICEMAN ICEMAN is offline
Default Re: evinrude 200- excessive smoke
HI, Yes an air leak or vacuum leak in the system will cause excessive oil consumption if you are using the VRO system.
  #3
Old March 29th, 2002, 03:30 PM
Dhadley Dhadley is offline
Location: Port Charlotte FL (almost -- its coming along)Never mind - it'll never be the same
Don't lean it out to get away from smoke. Smoke has more to do with oil quality and spark plugs. Use a good OE oil or Pennzoil synthetic blend, FRESH 87 octane and the correct Champion plugs. Yes, a fuel restriction or pump problem will cause it to dump more oil. Check it out and let us know.Good luck!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Excessive smoke '85 150 Evinrude sabbett4 Johnson & Evinrude Outboards 3 March 31st, 2007 02:08 PM
Excessive smoke ricksterpr Mercury & Mariner Outboards 12 February 26th, 2007 02:58 PM
1989 150 V6 Evinrude excessive smoke wormboy Johnson & Evinrude Outboards 5 July 29th, 2006 04:28 PM
excessive smoke tjbarta Johnson & Evinrude Outboards 8 January 9th, 2005 06:16 PM
Excessive smoke on Evinrude 40 VRO at idle Ferg55 Johnson & Evinrude Outboards 1 August 15th, 2003 02:18 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
