Re: lose prime 87 johnson vro
I think that I would disconnect the output hose from the VRO pump then install about a 6" peice of hose on the VRO hold the end of the hose in a glass jar crank the engine over and see if the VRO pump was pumping fuel. If the pump is pumping fuel then the next step is to find the air leak in the fuel hose, or primmer bulb.<br />good luck!
