Do any of you use a johnson or evinrude in the 9,9-15hp (1992 thru 98) for trolling?<br />I ask because the service manuals point out<br />that these models were designed NOT to allow<br />"hands off" steering. This is not acceptable<br />when one wishes to retrieve a lure to get rid of a weed, etc. if your buddy is trolling from the front of the boat.<br />As a result of all this, I ,and many others,<br />keep tightening the pivot shaft friction screw which results in the pivot shaft bushing being crushed and broken since it is composed of a hard, black, brittle plastic similar to bakelite (Part #332663).<br />As I do my own service work,I am in the process of replacing this bushing for the third time and it requires complete disassembly of the engine to do so. I have<br />discussed this matter with two or three<br />highly qualified Johnson servicemen and they report replacing this bushing regularly on many motors as they just don't hold up in service.<br />I am attempting a to find a "work around" for this problem and am considering making <br />a brass bushing for this application. If anyone else has had this problem and found a<br />solution, I would be eternally grateful for<br />any feedback I can get.<br /> jimfishes
