Help!<br />I've been on the lake 3 times tring to figure it out. Last time this happened it was a power pack. Idles fine and revs up great. When it's cold it runs down the lake fine about 5-7 minutes at full throttle (5800 rpms) it dies down to about 3200 rpms. If you stop rev it up w/o a load on it it revs fine. I've checked the fuel line bulb and tired to pump it while experencing the problem but no change. just bought the manual today but where do I start. is there any way to check the power pack w/o a spark tester for all 4 cylinders at the same time? any ideas or help will be appreciated.<br />Thanks for any help. <br />Keith<br />
