  #1
Old March 3rd, 2002, 01:19 PM
Trent Trent is offline
Default Re: 87 25hp evinrude bendix problem
If you dont want to remove the starter. Get some engine cleaner from the auto parts store or Wal Mart and spray it. Then wash down with water. Then re-lube with grease or spray with WD40 or some lube like that. You need to lube this thing several times per year.
  #2
Old March 3rd, 2002, 01:20 PM
Jerry A Jerry A is offline
Default 87 25hp evinrude bendix problem
Would anybody be able to explain how to clean the bendix on my starter on my 87 25hp evivrude motor? It sticks occationally, ecspecially in cold weather. I've been told to clean it with fuel oil? I took this in to Ed's boats in appleton wi,he charged me 80.00 and said it was fine,grrrr.Any help would be greatly appreciated. Thank you jer . nullnull
  #3
Old March 3rd, 2002, 03:59 PM
CAPTBLACKSMARINE CAPTBLACKSMARINE is offline
your starter bendix has a rubber bushing in it and according to omc/bomb you are not supposed to spray it with products such as wd-40 because they will make the rubber to slippery and cause the rubber bushing to slip .when the bushing slips the motor will not turn over .if the bendix is sticking you should lube the armature shaft with starter lube your local dealer should have some if you want to clean the shaft then you need to do so with a rag .if you need to remove the bendix and clean the shaft and the inside of the bendix,then apply lube on the shaft and reinstall .
  #4
Old March 3rd, 2002, 04:02 PM
forgot something . you do not want to use the harsh cleaners as previously mentioned either.they can deteriate the rubber bushing and also cause it to slip just as the wd-40 can.
  #5
Capt...Iv never had a problem! Iv owned several myself.Not to argue..It does need lube several times a year.
  #6
Old March 3rd, 2002, 05:33 PM
Thank You Capt. Do I pull the starter gear up even with the flywheel or just go ahead and take it apart right away? I have been told that this is due to the grease not letting it function properly, and this seems to be the case here, as when I take the cover off and tap the starter motor it will work just fine. THIS IS REALLY APPRECIATED.
  #7
Old March 3rd, 2002, 05:35 PM
  #8
Old March 3rd, 2002, 06:08 PM
that is something you will have to figure out when you look at it i have no way to know how much dirt or old grease you may have built up on it ,but if i had any doubt i would go ahead and pull the gear off and clean it all up and then lube it ,that way you should be certain to correct the problem and be done with it.
  #9
Old March 3rd, 2002, 06:15 PM
trent,i know quite a few people who have done what you had said .and no the problem does not usually occur the day they sprayed it and at times it may take doing so several times before the problem shows up .but eventually the bushing slips,i guess how long it takes before it slips will depend on how much spray is put on the gear and bushing when it is done .yes what you mentioned will most likely work but will cause premature failure of the bushing.
  #10
Old March 4th, 2002, 11:46 AM
Thanks Trent and Capt. I picked up the lube today and am going to work on this right now.Thanks again for your help. Jerbear
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1990 25HP Evinrude idling problem steve694 Johnson & Evinrude Outboards 1 August 3rd, 2006 02:55 PM
25hp evinrude - new problem (gas tank?) dynomike Johnson & Evinrude Outboards 2 May 27th, 2006 07:46 PM
Evinrude 25hp cold start problem OFD56 Johnson & Evinrude Outboards 3 April 25th, 2006 08:36 AM
Shift rod connection problem. 25hp evinrude smittyCrappie Johnson & Evinrude Outboards 5 January 6th, 2005 06:59 PM
Sticky Bendix On 70 Hp Evinrude rogerwa Johnson & Evinrude Outboards 1 June 1st, 2004 12:39 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
