  #1
Old August 5th, 2001, 07:21 PM
Seafare_Joe Seafare_Joe is offline
Default Evinrude 7.5 will not rev past half speed in forward
This engine will very high RPM's in both Neutral and Reverse. However when I change to forward gear, I only get half the RPM's even the the throttle moves to fill open. I have new Plugs, cleaned the carb. Any Help?
  #2
Old August 5th, 2001, 07:59 PM
Default Re: Evinrude 7.5 will not rev past half speed in forward
I do not know the exact age of the motor, (Original 1973 ??) But it has been on our 1973 sailboat since we bought her in 1987.------------------
  #3
Old August 5th, 2001, 08:53 PM
I am having similar problem. Let me know if you get the answer...
  #4
Old March 27th, 2007, 11:25 PM
Perfect3nemy Perfect3nemy is offline
I had the same problem on my motor. It turned out to be cracked o rings in the fuel line quick connector. Any leaks in the pressure tank or tubes will also cause this problem.
  #5
Old March 28th, 2007, 10:38 AM
Chinewalker's Avatar
Chinewalker Chinewalker is offline
90 percent of the time this happens, it is a matter the motor only running on one cylinder. Check for good spark on both cylinders. Might be as simple as installing new spark plugs. Could be a coil. Won't know until you trouble-shoot it.
Check for water on the spark plugs (indicating a blown head gasket).
Also, always post your motor's model number with your post. Evinrude built 7.5s in the 1950s and then not again until 1980. COMPLETELY different motors...
- Scott
__________________
Share A Project Page for 1971 GW Invader Banchie 13
http://www.shareaproject.com/pages/p...,p,433,00.html
Share A Project Page for 1976 American 18
http://www.shareaproject.com/pages/p...,p,404,00.html
Share A Project Page for 1974 American 15
http://www.shareaproject.com/pages/p...,p,405,00.html
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Motor shuts off when running past half throttle Grecon Johnson & Evinrude Outboards 0 June 29th, 2005 04:56 AM
Motor bogging down past half throttle tbordofske Mercury & Mariner Outboards 5 September 17th, 2003 04:20 PM
Motor bogging down past half throttle tbordofske Non-Repair Outboard Discussions 2 September 7th, 2003 06:17 PM
1969 evinrude running at half speed. DarrensBand Johnson & Evinrude Outboards 1 July 30th, 2002 01:25 PM
'71 9.5 Johnson; half max RPM in forward Bassmast Johnson & Evinrude Outboards 1 June 12th, 2001 02:13 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
