It simulates the mid section style of the 3.6 XP GT V8's. They had a molded in snout on the rear lower portion of the mid section just above the cavation plate. Opening the exhaust does indeed make it very noisy. As a rule of thumb, just opening the exhaust does not make the boat go faster (although it sure sounds like it) unless you dry stack the motor too. And then RPM comes into play.
Good luck!
